Home › Forums › Products › Stompboxes › H90 – Mono Out – Mono In Insert and Mono Out – Stereo In Insert › Reply To: H90 – Mono Out – Mono In Insert and Mono Out – Stereo In Insert
January 3, 2025 at 6:17 pm
#187445
The correct way to use pedals in the H90 inserts would be the following:
Out 3 into external pedal, out that pedal back into the H90 on In 3. Same thing for the second insert using I/O 4. This way those inserts could be moved around the H90’s signal flow at will.
Because the H90 can only have two mono or one stereo insert, there would be no way to send a mono signal and return a stereo signal for MISO functionality. You have to decide to either run the Onward in mono or stereo.
