Home Forums Products Stompboxes Split: Eventide Device Manager not working properly Reply To: Split: Eventide Device Manager not working properly
#187488
Have you tried these instructions?
  • Download and install the Direct Updater for your system: https://www.eventideaudio.com/downloads/?product=TimeFactor
  • Connect your pedal to your computer via USB
  • Turn the pedal on while holding down the middle footswitch until the display says UPDATE.
  • Open the Direct Updater application (NOT EDM). It will automatically scan for any devices. Once it detects your pedal, click OK.
  • Whether the application shows the serial number of your pedal or it says INVALID, it will show you the available firmware updates regardless.
  • Choose the first option (5.2.0[6]) to highlight it in blue and click “Install Update.”
  • After about 5 minutes, the pedal should be updated.
