Home Forums Products Stompboxes H9 rotary FAST/SLOW help!! Reply To: H9 rotary FAST/SLOW help!!
#187556
Pressing and holding the footswitch will engage the Brake control, which will eventually stop the LFO.
A short press of the footswitch will toggle between Fast/Slow. The LFO for Fast mode is the value determined by the Rotor/Horn speed parameters. When Slow mode is engaged the LFOs will slow down by a predetermined factor, simulating a physical Leslie cabinet slowing down.
The Hz display will not change when you toggle between Fast/Slow.
Let me know if you have any other questions.
