Home Forums Products Rackmount I hear a bug in 9000 Reply To: I hear a bug in 9000
#187680
    The Q factor is very extreme in this algorithm along with some of the other H8000 algorithms. I just tested and this behavior is the same on the H8000. I would suggest not turning up the Q on this algorithm, or using a different algorithm. ModFilter is a good choice for a dual filtered delay.
    The Vintage Delay algorithm loads with the LFO going very fast. Try turning the RATE parameter down to around 1-2 Hz.
