Home › Forums › Products › Stompboxes › Tremolo › Reply To: Tremolo
#187686
joecozzi
    I don’t have a Duophony but since it’s a parallel mixer, I suspect you’re running into the same issues as if you’d be running any of the tremolo algorithms in a parallel routing on the H90. See if you’re happy with the trems on the H90 in series first without putting your signal through the Duophony. Then figure out what mix of that signal has to be going through the GFI in the chain to give you the results you’re after.
