Home Forums Products Stompboxes Muting Output 1 on H90 Reply To: Muting Output 1 on H90
#187722
joecozzi
    Gig Rig Three2One > into H90 input 1 > Output 2 into front of Twin Reverb – this works great.
    Did you mean to say Output 1 goes to the Twin?
    H90 Output 2 goes to a Mixing Desk PA When I switch from electric to acoustic guitar (using the Gig Rig Three2One to select guitar inputs) is there a way to mute output 1 in the H90 so that the acoustic guitar signal only goes to the Mixing Desk PA and not the Twin Reverb?
    No, there isn’t a way to bypass Output 1 and Output 2 independently. You might need an external mute switch or volume pedal for the signal coming out of Output 1.
    Just making sure: Are you using the Force Mono feature of the H90 found in the I/O section of the System menu? In this configuration it’s necessary because normally, if you connect to outputs 1&2 it makes the H90 function in stereo, not dual mono as it sounds you’re using it in your setup.
