Home › Forums › Products › Stompboxes › 3 channels mixed? › Reply To: 3 channels mixed?
        January 20, 2025 at 2:29 pm
        #187831
Yes, you have your dry signal coming out of the first ToneX split into three paths. Please note that while the delay and chorus are in parallel, it may be a good idea to run those two stereo effects in Kill dry and control their levels using their respective output Mix levels. Otherwise, you run the risk of mixing three copies of your dry signal together and it may make the dry signal louder than it needs to be.
