Home Forums Products Stompboxes CC control of H90 Insert bypass / active Reply To: CC control of H90 Insert bypass / active
#188020
joebonn
    I recently got a Morningstar MC6 Pro and am running into this same issue.  It’s nice to be able to know for certain with visual confirmation if an insert is engaged or not when activating a Program.  The MC6 has a lovely Toggle State that allows you to program 2 positions for one switch, where one represents CC=0 and the other CC=127, so that you can see the bypass state upon switch press.  This seems to work with P, A, B act/bypass states (although requires a 2nd press if you send it a Bypass message when the program or preset is already bypassed.
    Any update on whether or not this will be implemented?
