1416 Four Filters, some parameters not working
Home Forums Products Rackmount 1416 Four Filters, some parameters not working
Viewing 3 reply threads
    • #165603
      klango
        I just discovered these and like them a lot. Regretably, the master parameters for filter type and order don’t work. And Q only works on the bandpass, not on the highpass and lowpass. Any chance this could be corrected? Thank you
        Peter
      • #165604
          Please see this post and I think that will answer your questions – https://www.eventideaudio.com/forums/topic/1416-four-filters-only-filter-1-works-on-h9000/
        • #165605
          klango
            Actually it doesn’t because that post deals with a routing question. I have no problem hearing signal through all four filters. I’m talking about those two master controls not working, as well as Q on lo and highpass.
          • #165607
              Thanks, ok I’ve made a ticket to have the developers look into this, but I cannot provide a timeline for when this will be fixed. I would suggest not using the master parameters for now.
