2410 MIDI Harmony- Separate ouputs
Home › Forums › Products › Rackmount › 2410 MIDI Harmony- Separate ouputs
Viewing 3 reply threads
    • #112137
      Hello all,
       Is it possible to output the 4 shifters in MIDI Harmony to 4 separate AES outputs as opposed to a stereo mix? Thanks.
    • #127111
      nickrose
        The preset is set up for a stereo output – the four shifters are fed into a stereo mixer.
        You could change this using Vsig, but otherwise it is set.
      • #127112
        Thanks for the quick response, Nick. I'm new to Vsig, but would this be a relatively easy modification to the existing program or would it need to be rebuilt entirely? Thanks.
      • #137730
        nickrose
          It would be pretty easy – you want to add two more outputs, then connect the shifter outputs to them, skipping the current STEREOMIXER module.
          Or, better, you could replace the STEREOMIXER with a QUADMIXER, which could preserve the gain and pan controls. But, then you'd have to add f/r pan knobs … it gets complex. Probably better to just route the shifter outputs to the main outputs.
