Home › Forums › Products › Stompboxes › 32 bit floating point
- This topic has 10 replies, 5 voices, and was last updated 2 years, 1 month ago by davemevans.
November 22, 2022 at 1:52 pm #166960davemevansParticipant
Is the H90 A/D converter(s) 32 bit floating point? 32 bit A/D accuracy in pedal effect quality makes a lot of audible difference to acoustic instruments in my experience e.g. as in the GT1000 or the strymon effects are much clearer on a quality acoustic guitar than 24 bit pedals. I’d buy one if it is 32 bit or above.
November 22, 2022 at 1:55 pm #166961brockstarParticipant
Sample rate 48 kHz AD/DA 24-bit, DSP 32-bit floating point <– from the manual
November 22, 2022 at 1:56 pm #166962brockParticipant
From the H90 FAQs: 48 kHz, AD/DA 24-bit, DSP 32-bit floating point.
November 25, 2022 at 10:39 pm #167112noodle1Participant
A/D on the BOSS is 32-bit / 96 KHz and DSP is 32-bit floating point
A/D on the Eventide is 24-bit / 48 KHz and DSP is 32-bit floating point -
November 26, 2022 at 9:25 am #167114PRSGUY513Participant
It’s the quality of the DAC’s that really matter. Having 32/96 of noisy, lifeless headroom is pointless.
November 26, 2022 at 11:39 am #167117davemevansParticipant
<p style=”text-align: center;”>Thank you for the information.</p>
November 27, 2022 at 2:55 pm #167134PRSGUY513Participant
Yes. Maybe I should have written a disclaimer with that…Always try before you buy!!!! They know people are basing (too much) of their decision-making on these ratings. DO NOT rely just on manufacturer specs…
👍Yes you’re right. And it’s really tough to sort through so much of it. I have the advantage of an electronics background, but it still takes using it firsthand. I sometimes forget that people are using these pedals for more than electric guitar which for the most part these days the sound quality is plenty sufficient, especially for live use.
November 28, 2022 at 2:29 am #167144davemevansParticipant
The clarity gain for acoustic instruments of 32 pedals is marked. But even electric guitarists talk about extra ‘responsiveness’ of such pedals e.g. The gt1000 (32 bit) increase in sound quality over the gt100. There’s a good YouTube video of the sound difference between the two with the same settings that clearly demonstrates the difference in sound quality on quality speakers. The extra definition / quality is important for acoustic instruments especially if they are played gently. Electric guitars less so I feel.
November 28, 2022 at 4:57 am #167145PRSGUY513Participant
Theoretically it is technically true, but I’ll take my Fractal FM3 or AxeFXIII with its 24bit/48kHz converters over a GT-1000 any day of the week and twice on Sunday. There’s so much more to the whole equation. The other thing that I always question is the fact that most everything will be down converted or digitally compressed at some point for mass consumption. If in fact the integrity can be maintained from beginning to end then it’s worth it. Admittedly it’s always best practice to get the highest quality take as possible regardless of what happens afterwards. I guess I just see these processors as performance gear and as long as the analog circuitry before and after the conversion process is up to snuff 24bit is sufficient. Or, I really wonder if the perceived 32bit difference is more placebo or some other aspect of the design of say, the gt-100 to the gt-1000. The coding of the Algorithms can make or break these types of processors. In the end it’s whatever makes you happy and want to play.
November 28, 2022 at 5:52 am #167146davemevansParticipant
How can it be a placebo if I say I can clearly hear the difference? Please try not to be rude when replying, and as I said my question applies to acoustic instruments not distorted mid heavy tones of electric guitars
