Home › Forums › Products › Vsig and Preset Development › 8523 Sci-Fiction Delays Multiknob error
- This topic has 4 replies, 1 voice, and was last updated 3 years ago by John Baylies.
August 12, 2020 at 8:54 pm #116037rskaudioParticipant
Attempting to open 8523 results in the attached error
“Device Download Error
module: Multiknob
Field: type”
Also, odd capitalization in the error…
module: Multiknob
Field: type”
I’m seeing the same thing on the 5.1 Chamber reverb types. It looks like there is no ‘type’ parameter in ‘multiknob’ but the preset has it.
December 28, 2020 at 5:07 pm #156697zazulaParticipant
Additional info. I tried editing the database JSON file to correct the error, but am having no luck.
Trying to download #4246 – “Reverb Suite”, I receive:
Module type or field could not be identified.
Module: multiknob
Field: type
Looking in VSig.app/Contents/Resources/Assets/default-sigdb.json there is indeed no ‘dsize’ entry in toe ‘multiknob’ definition. I used one of the other ‘dsize’ entries and added it, but I still receive the same message.
{“type”: “ED_CONTROL”,“name”: “dsize”,“isMultiple”: false,“description”: “size”,“minimum”: “0”,“maximum”: “1”,“default”: “0.5”},I’ve verified that VSig is loading my database file by zeroing it out and receiving an error (no modules).Any suggestions on how to get past this error? -
December 28, 2020 at 9:06 pm #156706John BayliesParticipant
We're aware of the Device Download Errors. Fixing the underlying issue requires some refactoring, which will happen sometime after the Emote 1.4 beta is released.
February 3, 2022 at 12:57 pm #162004John BayliesParticipant
H9000 firmware 2.0.5[2] fixes this error for many algorithms, including #8523.
