88.2khz / 96 khz probs with H8000FW
Home Forums Products Rackmount 88.2khz / 96 khz probs with H8000FW
Viewing 7 reply threads
    • #105867
       been having a LOT of probs tring to run my H8000FW via firewire at either 88.2khz or 96khz, either shows dsp a overload or wont get any signal at all.
      i am runing mac G5 with OS X 10.4.11
      when i use it at 44.1k or 48k is fine , but whatever settings i try , when i attempt 88.2 k 0r 96k no joy 🙁
      would be grateful for any advice here
      many thanks
      Charlie
    • #117919
       Hi Charlie
      what OS version is your H8000FW running on?
    • #117921
       Is running OS 5.21 at the moment
      best
      C
    • #129084
       Charlie
      we have OS V3.5 and new  FW drivers for Mac/XP/Vista available on the website. These should support higher sample rates thry FW. Please update your unit/computer.
      best
    • #129085
      nickrose
         You should upgrade to V5.3 and install the new drivers – this has a lot of FireWire improvements. On the Web Site support section.
        Note that the performance also depends a lot upon your computer settings, which are beyond our control – be sure to read the relevant sections of the updated User Manual.
      • #129086
         Sorry! Version 5.3 is the correct numbering.
        Idea
      • #129087
         cheers for the info ,
        i have installed the  new comp drivers on my Mac but havnt upgraded to 5.3 yet, going to do it today.
        will also check updated manual
        thanks
        Charlie
      • #129093
         Hi
        just wanted to say big thanks for your help ,
        i have updated drivers and op sys to 5.3, and now unit is working fine at 88.2k and 96 k  🙂
        cheers guys
        Charlie
