A/B switching with the H90
Home › Forums › Products › Stompboxes › A/B switching with the H90
Viewing 4 reply threads
    • #187983
      Securb
        Is there a way to switch between effect A and effect B in a preset with one button instead of turning one off and the other on?
      • #187984
        joecozzi
          It’s possible to do with MIDI. Best to just have two separate Programs and switch between them. In Bank mode, for example, each program has their own button, so one button press has the same effect.
        • #187985
          Securb
            Thanks
          • #188037
            pinkgary
              yep, you can assign the same hot switch to bypass A and un bypass B; save it with B bypassed, bingo.
            • #188117
              JermainMarks
                @uno online yep, you can assign the same hot switch to bypass A and un bypass B; save it with B bypassed, bingo.
                Oh. New knowledge has been acquired. thank you.
                But my account does not show A and B buttons??
