September 24, 2010 at 9:26 pm #107282DarioMember
Hi folks,
i would like to understand the reason of this sound/path process,
to make this,I need to explain the chain of my setup,
it includes two Markbass Combo Amps (CMD 121H),the 2 Sends and the 2 Returns on the rear panel of my combo amps,feed the Ins and Outs of my H8000,for a perfect stereo path,in a typical send/return wiring
my bass,through a volume pedal,goes in One frontal input of an Amp
Markbass Combo Amp 1send
>H8000 IN 1Markbass Combo Amp 2 send
>H8000 IN 2Markbass Combo Amp 1 return
>H8000 OUT 1Markbass Combo Amp 2 retrun
>H8000 OUT 2bass—->in Volume Ped out
> Frontal Input of one of the 2 Ampsnow,my question: is normal that I listen to an higher volume sound on an Amp,let's say the 1 and I listen to a lower and almost completely wet signal on the other Amp?
September 24, 2010 at 9:42 pm #120782
More questions. Sorry.
1) What routing are you using ?
2) What presets does this occur with ? (Name at least one).
3) Does it make any difference if you remove the volume pedal ?
4) Do you get the same thing with a THRU preset ?
September 24, 2010 at 10:24 pm #120783DarioMember
the routing is A-B(the first one on the routing menu)with the wet/dry Level at 50% on DSP A and DSP B
an example Preset:
6518
6518
6519
6519
also,with the preset #218 I listen to only the Wet sound on an Amp and I listen to a complete Dry sound on the other Amp
I have to try if It does any difference if I remove a volume pedal and if I load a THRU preset
thanks a lot
September 24, 2010 at 10:38 pm #120784DarioMember
an example Preset:
6518
6518
6519
6519
also,with the preset #218 I listen to the Wet sound on an Amp and I listen to a complete Dry sound on the other Amp
thanks
September 25, 2010 at 10:56 am #120785DarioMember
Hi nickrose,
excuse me for the mistakes on the multiple replies answers 🙂
anyway,based on your questions,I've tried everything both without the Vol.pedal and in THRU too, this is the final result:
with a preset like the 6518(Pcm 70 Sax Hall) this is the result:
on the Fronta Input of the Amp 1,where is connected my bass, I listen to a litlle bit higher volume signal,with a good balance between the sound of my bass and the wet sound, instead on the Amp 2,where there isn't connected anything on the Frontal Input,I listen only a full wet signal.
with a preset like 218 (Gorgeus Delays),with the same wiring,I listen to the sound ONLY on the Amp 1,where is connected my bass,on the Amp 2 there is NO SOUND.
the same happens if I load the preset #12 THRU,the signal becomes MONO,like the preset #218(Gorgeous Delay) and I only listen to the sound on one of the 2 Amps.
also,with the help of my DAW,I've noticed that when I load THRU or a preset like the #218 the signal is Mono,when I load a preset like the #6518 the signal becomes Stereo,but with the problem that I listen to a different kind of sound on the 2 Amps,as I said before.
the only way that I found to solve this problem,is to use an Y cable jack mono—dual mono,
but I guess that this is not the best solution,
let me know
