- This topic has 6 replies, 3 voices, and was last updated 1 year, 1 month ago by
Puppeteer.
March 14, 2021 at 4:32 pm #116401
John Baylies
ParticipantHere's how I use Ableton's External Audio Effect device to record audio through an FX Chain on the H9000.
With my audio interface, Live's 'Audio To/From' 5/6 corresponds to the H9000's 'MADI A' 1/2
The above is functionally equivalent to the below:
March 14, 2021 at 10:08 pm #157439
zengomi
ParticipantThank you, John, for starting a new thread and sharing your Live recording methods.
Can I assume that those methods would work if the ‘clip’ track had Audio From an external source?
March 14, 2021 at 10:32 pm #157440
John Baylies
ParticipantYes, that would work.
July 26, 2022 at 3:42 pm #164771
loomloom
ParticipantSorry for the noob question but if you are sending audio from your interface output on 5/6 stereo and going to your h9000 on 1/2 why does the ableton device say audio from 5/6? (I was expecting to see 1/2 here) Unless this mean you’re also going back into 5/6 on the input side of your interface?
July 28, 2022 at 1:22 am #164817
Puppeteer
Ableton output refer to the specific outputs on your soundcard. For example on my RME UFX the ADAT outputs start at output 13. The ADAT cable goes into my H9000 and they are channels ADAT 1-8 on the H9000.
Ableton has no idea what external devices enumerate devices as. It only knows what soundcard output to route audio to. Your H9000 has no idea what ableton has labelled the outputs, it only knows it’s own input channel layout.
January 4, 2024 at 12:18 am #177044
sugarhi
ParticipantHow are you dealing with latency? Monitoring and recording of wet signal?
Cheers
January 4, 2024 at 12:25 am #177045
Puppeteer
ParticipantI use Ableton’s external effect, where you can specify the latency.
