about H90 insert routing
Home › Forums › Products › Stompboxes › about H90 insert routing
    • #166406
      afortuna
        Hi, very interesting box the H90. wonder if the insert routing is subject to the algorithm routing?
        example1: from a mono input, can i route two mono inserts in parallel, mix them, and then go through both algorithms in series?
        example 2: rout a mono insert in parallel to an algorithm, mix and then go through the other algorithm?
        EDIT: oh also, is there a way to filter the signals pre/post the inserts? lets say a want to process in parallel the bass part of a signal through one insert and the highs on another? so to work in a sense like a X-over?
        Thanks in advance.
      • #166489
          Sorry but the insert routing examples you have mentioned are not possible on the H90. Two mono inserts can be routed individually at various points of the signal path, but when they are routed next to each other Insert 1 is always routed in series to Insert 2 (they cannot be routed in parallel and then processed by the algorithms as mentioned in your first example).
          You can use the algorithms to process the signal pre/post the inserts with filtering, but not in a way to split the hi/low frequencies to 2 separate insert paths.
          You can see a table of the available routing options here: https://cdn.eventideaudio.com/manuals/h90/1.1.2/content/edit-modes/routing.html#insert-routing
