October 8, 2008 at 8:07 pm #105870
hi,
I use the ADAT H8000fw configuration like this :
guitar + vocal -> rack preamp -> H8000fw -> H8000fw output ADAT -> ProjectMix ADAT input -> DAW (sonar 7)
also : DAW (sonar 7) -> ProjectMix ADAT output-> H8000fw input ADAT -> H8000fw output ADAT -> ProjectMix ADAT input -> DAW (sonar 7).
My question is: can I use the Adat and the firewire input/output in the same time ?
The goal is to have more input/output, because the adat is limited to 8 channels. It is possible ?
In fact, can i have Adat + Firewire? to have 16 input/ouput ?
thanks
October 8, 2008 at 9:08 pm #117922
You can use ADAT and both FireWires, giving you 24 channels of I/O, as long as you connect them to something useful, within the routing rules of the H8000.
For example, you could connect FireWire2 to ADAT, and FireWire1 to the H8000's main input/output.
October 9, 2008 at 5:08 am #117923
If I understand you correctly you want to use both your Project mix and the H8000FW as sound cards or input devices at the same time?
If this is the case then I'm not so sure that Windows and Sonar will allow this.
If Sonar does have the ability to run two input devices at the same time then you should be able to do the above.
October 10, 2008 at 10:15 am #129095
thanks for your reply Sonic Nomad.
do you know a DAW / Operating system that do this : have different input devices in same time ? -
October 10, 2008 at 10:18 am #117926
thanks for your reply nickrose.
But i don't understand very well. Can you schematize this (connect FireWire2 to ADAT, and FireWire1 to the H8000's main input/output) ? How can i do that ? -
October 10, 2008 at 3:36 pm #129096
Basically you have to understand the H8000's routing and memorize the User Manual. You could also try the Routing utility available from the Web Site, which will give you the schematics you request.
Or, load factory routing "14 FireWire A-B". Then go to SETUP and hit the "outputs" key until you see "ADAT Outputs" in the top right. Turn the wheel until you see "FWIRE2 in 1" etc. This will connect the FireWire 2 input to the ADAT outputs. Similarly, connect ADAT inputs to the "FireWire2 outputs".
Actually using this with a DAW is, however, beyond the scope of this forum.
October 10, 2008 at 11:55 pm #129097
Eek… Memorize the user manual. I can't even memorize some important nos. lol
I think what Nick is saying is you really do need to spend time with the manual and get a better understanding of the H8000, else she'll make you feel like a little whipped puppy. 🙂
It's very late here. I'll pop in overt the weekend and post why this was done and how it works.
October 11, 2008 at 1:33 pm #129098
On Mac using Core Audio drivers allows users to have multiple sound devices "AGGREGATED". This is a feature that built in the OS and is a great solution if you sound card or device supports it.
Currently I can't use this feature as my Digi 003 doesn't support it.
But there are many other products that do.
October 11, 2008 at 1:54 pm #129099
I was tired and posted this to the wrong thread so I'll just continue as this is of some relevance here and I'll post a link from the other thread to this one.
So the forum crops the picture… not good
Here's a link to the image -> http://www.davidteren.com/pics/h8000-logic.jpg
Having given it some more thought I decided to compile a PDF explaining this setup and how to use it in a DAW like Logic. However this is going to take me several days to complete so please be patient.
October 17, 2008 at 7:46 am #129110
So the 2nd FW connector is not only for mutiple units? Can I connect this to the same computer as FW1? Can i route like a sort of send (fw1) en return (fw2)?
what else can I do with the 2nd fW option?
October 17, 2008 at 12:15 pm #129112
You can route sends and returns on a single FW. The second one is for daisy chain other FW units, even though sharing the bus will slow things down a bit.
FW is not THAT fast, especially when multiple devices are sharing the same bus.
Thebest option on a computer is to have mutiple FW ports *on separate busses*, adding PCI/PCI Express cards for the task.I
October 19, 2008 at 11:53 am #129115
Thanks for your reply Sonic Nomad.
I search on the web and i see this :
http://www.CEntrance.com/products/ud/I have not test this , but it seems this driver "aggregate" sound devices on windows.
Does anyone test this for the eventide h8000fw ?
