Add hardware mono compressor for send/return
Home Forums Products Rackmount Add hardware mono compressor for send/return
Viewing 4 reply threads
    • #107273
      teddy
      I installed the routing utility but i need help. I want to modifiy the routing preset 21 "firewire 8 tracks A&B" to use an hardware mono compressor. I want to plug the compressor on the analog input 1 and analog output 1, and send my mono signal in Logic (voice track) to firewire 1 and get the compressed signal in firewire 1 out. But continue to use others firewire input/output to mix.
      Can you help me please ?
    • #120766
      teddy
      Someone to help me Sad ?
    • #120769
      Not clear what your problem is.
    • #131974
      teddy
      Hi nickrose,
      I just want to use an hardware compressor in a send return configuration of the H8000, while using a preset like  : "firewire 8 track" for mixing. How can I change a routing preset (for exemple "firewire 8 track") to use my hardware compressor ?
    • #131975
      Changing the routing is extensively described in the User Manual, and can also be done with the Routing utility. It is not the simplest thing, but most people can understand it with a bit of work.
      If you find it impossible to understand, I'll have to ask you to draw out what you are trying to do (words are no help here) and email it or post it to support@eventide.com, marked for my attention.
      Please try working with the User Manual first – it will sav us both time.
