Adding a Swell/Volume pedal function
Home Forums Products Stompboxes Adding a Swell/Volume pedal function
Viewing 21 reply threads
    • #112371
        Many people have asked that we add some volume or swell pedal functions to our pedals, probably one before the effect, and another after the effect. We are considering this for a future release.
        There are a number of unclear issues here which are worthy of discussion. Nothing is simple.
        1) Should such a setting be global (meaning always active), or only active on a preset by preset basis? People viewing it as a volume pedal might want it always global, whereas a swell pedal might be used on some presets and not others. We have some examples of things that can be selected as either global or preset based (mix, tempo, etc), but too many of these causes confusion.
        2) If these functions can be controlled by the Expression pedal, what would happen to preset parameters controlled by the pedal – should such control be disabled when the pedal is active in volume/swell mode, or might people want both functions active at the same time ?
        3) There currently is no concept in our stomps of using the Expression pedal as a general controller (it is only used to control preset parameters). Adding this might be fiddly, and would bring up the issues in (2) above.
        4) Our though is that the level settings for these features should not be saved at powerdown, so as to be sure the pedal will have full output when next switched on. An apparently dead pedal will cause a flood of unhappy customers.
        5) It appears to us that there is little need for manual control of these levels, as it would be almost always driven by some sort of pedal or controller. This also relates to (4) above.
        So, the easiest (and hence quickest) way to add this feature would be to make it global (always active) and restrict it to MIDI control only. Would this be useful ?
      • #127581
        I'm thinking in a simple approach with the Timefactor in mind. I'm pretty sure that a lot of people might want a more "real" volume pedal embedded in the Stompbox by controlling it with an Expression Pedal.
        It will take a simple switch stomp, similar to "rpts", to activate and deactivate.
        User can select either (rpts or swll) to use in "Play mode" by pressing the middle switch.
        Decay time, from 0 to 10+ secs, set by the user in the globals menu.
        MIDI, sure, why not.
        Make it global.
      • #138363
          Thanks for your reply, but it illustrates some of he problems we face:
          1) There is no available switch to activate it (on all presets), so it will probably be on all the time, or on a preset by preset basis.
          Although, maybe you mean is that you could cycle the switch by pressing it twice to select "Swell" mode  (would this be too fiddly ?) – it would go normal -> rpt -> swell – > normal..
          2) If it was on, would it also control parameters in the normal way ? But maybe if you used the switch operation described above, when it was in swell mode it could defeat all other expression functions
          This might work if the cycling mode was not too confusing.
        • #138364
          No, I meant to give the middle switch the following options within the System Menu (Globals/Utility):
          MIDDLE SWITCH:
          SWELL | RPTS
          I don't see why other parameters (besides mix/decay of course) might change when using "Swell".
        • #138368
          LA Keys
            Sniff, there's no middle switch on my H9s  Crying
            LA
          • #138379
            Don't worry. There's always MIDI.
          • #127585
            ROBLEISHMAN
              Midi control as described would be handy, however, maybe i'm missing something, but could the input gain parameter by controlled to same way as the preset parameters are controlled? ie hotknob values)?
              If so, couldn't a post gain parameter be added and controlled in the same manner, this would give us pre and post volume control using an expression pedal.
              On a side note, it would also be swell if there was some way to edit the value curve of an expression pedal. something simple like 0.0 volts = hotknob val 0 – 1.0 volts = hotknob val 20 – 5.0 volts = hotknob 100. This would allow us to create a smoother expression curve for whatever expression pedal we are using, i've always wondered why this isn't a standard parameter on digital pedals.
            • #138382
                spaceJam:
                My concern is that many presets may have expression pedal assignments to various knob parameters – the issue is whether these should still work when using the expression pedal for swell.
              • #138383
                ROBLEISHMAN
                  Why not? This is how the current parameter system works right? chances are if you need a swell, your not going to have a wah effect at the same time right, so you could make 2 versions of the preset, 1 with swell hotknob values another with filter values…
                • #138384
                    OK – we've given this some thought and listened to your suggestions and this is our current thinking:
                    1) There will be system parameters for MIDI control of InSwell and OutSwell. Aux switch control will NOT be supported (on/off only – not very useful).
                    2) There will be parameters to enable/disable Expression pedal control of InSwell and OutSwell. These can be saved either with each preset or globally, depending on new settings on the Global menu in system mode. When Expression pedal is enabled, any pedal controlled parameters will also be controlled.
                    3) The hardest part – how to  control the parameters in (2). We're a bit short of spare controls on the pedals, AND we want them to work the same way on both H9 and Factors – this means we can use neither middle switch nor HotKnob. Sorry. This is a bit fiddly, but we can't think of a better way – it does at least simplify gain setting on H9.
                    Our best effort for this is to change the way the current gain settings work. If you press and hold the left switch, it will go to Active mode and bring up the current Preset Outgain value, which you can adjust with the encoder.
                    H9 Only. Pressing and holding the encoder will bring up Input Gain value, which you can adjust with the encoder.
                    Pressing and holding the encoder again will bring up InSwell, which you can enable/disable with the encoder.
                    Pressing and holding the encoder again will bring up OutSwell, which you can enable/disable with the encoder.
                    Pressing and holding the encoder again will return to Preset Outgain.
                    After 5 seconds of no changes, or if any other switch is pressed, the unit will return to normal, restoring the prior Active/Bypass state.
                    Some new additional details:
                    1) If global is ON, the swell will be always enabled. If it is off, it is enabled on a preset by preset basis as described above.
                    2) If global is off, the swell will be reset to full level on loading a preset with swell disabled.
                  • #138386
                    ROBLEISHMAN
                      I'm picking up what your putting down…
                      This all seems reasonable to me.
                      Thanks for asking the forum about this it is so cool to know what may be coming up in the next update.
                    • #138390
                      cowudders
                        what a great addition!!
                      • #138393
                        Apologies, not sure I'm grasping the concept of what you're talking about adding.  Is this to act as an "auto swell" type feature?
                      • #138394
                        gkellum
                          acsewalk:
                          No, Nick is talking about adding a way to make either the input gain or the output gain controllable with an expression pedal or MIDI.
                        • #138398
                            I never got the chance to chime in on this design-in-progress, but my reply would've been nearly identical to nickrose / Eventide's conclusions.  Very versatile, and well thought out.
                            The only small item that hit me was the exclusion of Aux switch control.  Non-essential, for the most part.  But if the Aux Switches had the same treatment as KB0-KB9 control [MIN VAL and MAX VAL], they could be used to toggle between two preset InSwell / OutSwell level values.  Just a thought.
                          • #138400
                              We'd thought about what you suggest, but could not think of a clean way to set min/max values on the 'Factors – these have knobs which can select them – whereas the swells do not. One might think of using the pedal, but this is already used to select the mins and maxes.
                              Plus, it was already getting difficult….
                            • #138404
                                That makes a whole lot of sense, Nick (difficulty setting the Aux values).  I was thinking about another 'feature sell', but not so much about how to actually implement it.
                                Using the EXP PED for MIN & MAX values would be awkward and inaccurate, at best.  And the encoders / HotKnob are doing enough already.  Respectfully submitted & withdrawn.
                              • #138418
                                Styrioci
                                  sounds great, controlling swells like another parameter on preset basis sounds like lot of fun in combination with other parameters controlled by exp pedal
                                • #138419
                                    styrioci:
                                    I think this was a key decision, and the main one I was hoping to have implemented.  Among the many other applications across the 'Factor / H9 algorithms, InSwell is one component missing for accurate XP-300 Space Station presets (for example).
                                    I'm curious to see how it all interacts with envelope-controlled effects, or pitch shifts and mix.  We all know how useful this is going to be with delay lines.  But parallel parameter control as a per-preset option is as versatile as it gets.
                                  • #138458
                                    badmelonfarmer
                                      Good point regarding existing envelope effects.
                                      given a lot of posts asking about "Auto Swell"… Where possible / makes sense… I think people would also like a envelope control where a physical expression pedal is not present or needed… Obviously this would clash with some other envelope controlled effects.
                                      i guess another option would be to build a dedicated algorithm arround auto swells… I am sure you guys could create some cool things arround filters, shimmers, crystals etc.
                                    • #147680
                                      Etienne
                                        By the way, is this modification (swell/volume through the expression pedal) included in the software 3.5.0[4] ? or I miss something ?
                                        I really want to remove my volume pedal in my pedal chain…
                                        Thanks
                                        • #147681
                                            No – this was added as an update. You should update to the latest software.
                                        • #147777
                                          For me a good enough solution would be a Volume algo, that you program as a preset which basically controls the volume via an expression pedal. I can recall that patch via midi if i need a volume pedal. Job done.
                                          i would need to pre / post feature on the patch then i can have it at the end of the chain or at the start.
                                          simples.
                                          • #147778
                                              da7thson wrote:
                                              For me a good enough solution would be a Volume algo, that you program as a preset which basically controls the volume via an expression pedal. I can recall that patch via midi if i need a volume pedal. Job done.  i would need to pre / post feature on the patch then i can have it at the end of the chain or at the start.
                                              simples
                                              Something like this should work for you:
                                              With my Roland EV-5’s, most of the swell control is in the upper 2/3rds of the pedal throw.  It’s possible to snap between two fixed volume levels, with a ‘parked wah’ position (toggling the left Active / Bypass footswitch).
