Adjusting two delays
Home › Forums › Products › Stompboxes › Adjusting two delays
Viewing 3 reply threads
    • #107059
      georgev
        Ηι! I have a question. I wonder how can I create a double delay. I want the Delay A to be 1/8* 450ms & the Delay B 1/16 150ms. I ask that because when i adjust the first delay I don't know what to do to adjust the second without loosing the settings of the first.
        Thanks
      • #120362
        madmac
          why don't you set the subdivision up i.e. 1/8 A & 1/16 B and then just tap in the tempo of the song?
        • #120364
          georgev
            yeah u right. I do that. But my question was if it is possible to adjust separate time and type for each delay.
          • #131608
            If you mean by type subdivision like 1/8, 3/16 etc, then no, because you can either set your TF to work in Tempo mode (working with subdivisions and a "master" bpm) or in a "normal" mode with delay times shown in milliseconds.
            It wouldn't make any sense to tweak your delays otherwise unless the tempo of a song is changing.
            Having the ability to set delay A in 1/8 triplets at 120 bpm and delay B in 1/4 at 156 bpm (for example) is kinda strange.  The actual repeat times would be overlapping at some point, because 1/4 at 220 bpm is the same as 1/8 at 110 bpm. Know what I mean? You would be changing your frame of reference.
            If you need two separate tempi, you could just use two presets within one song.
            Hope I got that right.
