Advice on recreating H9 ‘Guitars in Space’ on Plugin
Home Forums Products Plug-Ins Advice on recreating H9 ‘Guitars in Space’ on Plugin
Viewing 4 reply threads
    • #186743
      rens
        Hi-
        Does anyone have advice on recreating the H9 pedal Band Delay “Guitars in Space” Patch using the H3000 Band Delays mk2 plugin?
        I attach some screen shots of the closest I have been able to get, but its not that close.
        Any advice gratefully received.
      • #186966
        rens
          Nobody? @eventide?
        • #187044
            Here’s a preset that I’ve created that gets pretty close to the H9 preset: https://etide.io/NB1cE
            The H9 version of Band Delays is only 2 voices that are hard panned left/right. The plug-in has 8 voices with much more flexibility, but if you want to recreate presets from the H9 you will need to limit some of the functions of the plug-in.
            Let me know if that helps.
          • #187320
            rens
              Hey thanks @tbskoglund … its in the zone and I can tweak from there to get where i need. Very helpful. your patch is way cleaner than the pedal version.
              Happy new year!
            • #187327
                Glad to hear that worked for you!
