AFX3 into H9000 via SPDIF RCA
Home Forums Products Rackmount AFX3 into H9000 via SPDIF RCA
Viewing 3 reply threads
    • #168293
      bxlgotham
        I have my Axe going into the H9000 via RCA SPDIF, from the Axe’s SPDIF output. I have the H9000 TOSLINK optical output going into my Apollo X4. I don’t see the signal making it into the X4, and I see the output1 block on my Axe is generating signal. Where do I go in the H9000 to monitor incoming signal? Where could the break be?
      • #168294
        joecozzi
          Hello bxlgotham,
          On the H9000, only one of the following protocols may be active at a time: ADAT, S/PDIF Optical, S/PDIF RCA, AES3 XLR, or AES DB25. This is configured on the front panel’s Clock menu page, or in Emote’s Setup View. It seems you’re trying to use more than one in our setup – RCA and Optical. Is it possible to come out of the Axe with TOSLINK and go out of the H9000 with TOSLINK? That would work.
        • #168297
          joeydego
            Hello bxlgotham, On the H9000, only one of the following protocols may be active at a time: ADAT, S/PDIF Optical, S/PDIF RCA, AES3 XLR, or AES DB25. This is configured on the front panel’s Clock menu page, or in Emote’s Setup View. It seems you’re trying to use more than one in our setup – RCA and Optical. Is it possible to come out of the Axe with TOSLINK and go out of the H9000 with TOSLINK? That would work.
            I think he is using a converter in between the AxeFXIII Spdif and the H9000 to get it to toslink.
            H9000, in Emote’s menu, go to Meter Bridge. You can select 8 ins or outs and see signal there but even easier and more importantly……have you set up any FX chains yet? You won’t have signal passing thru the H9000 if you haven’t as you haven’t made any virtual connections yet.
          • #168370
            bsfreq
              Yes, use spdif to toslink converter, set S/PDIF in as clock source in H9000 settings (and slave the apollo by setting it’s clock source to optical in)
              Then make the proper routings in the H9000.
