Algorithm Load Mutes FX Chain
Home Forums Products Rackmount Algorithm Load Mutes FX Chain
Viewing 0 reply threads
    • #187907
      gustebeast
        When loading an algorithm, it mutes the entire FX chain briefly. This is problematic if you are using a single chain for multiple parallel audio signals, in my case 2 mics with 2 algorithms each.
        Would it be possible for the H9000 to mute only the signal chain impacted by an algorithm load?
