- This topic has 6 replies, 4 voices, and was last updated 2 years, 2 months ago by
Eventide Staff.
June 18, 2022 at 4:34 pm #164112
I have had a Quadravox plugin for a couple of years. Never used it, as after 2 hours of frustration, going round registration loops, it just opens every time saying “Product requires activation” It sdays I do not have a license in iLok, despite my iLok manager clearly showing it there.
Having just purchased a 2016 Room Reverb, downloaded the installer, registered the plugin on the site and activated the license in iLok. I have just been reminded why I dont buy Eventide. Another 2 hours, only to achieve the same result. Never had this problem with any other manufacturers. Has anyone else experienced this? It is very frustrating.
June 18, 2022 at 7:20 pm #164113
Well the second of these was my fault, as I had downloaded an installer for a different plugin with an almost identical name. Quadrazvox still no resolution however
June 20, 2022 at 9:35 am #164122
Sorry for the issues you are having. Please see below and do the steps that apply:
Windows:
1. Confirm that you have the latest version of the plug-in installed: https://www.eventideaudio.com/products/plugins
2. Confirm that you have the latest version of iLok License Manager installed.If you already have iLok License Manager installed, open iLok License Manager and select Help → Check For Application Updates. If you do not have iLok License Manager installed, download the installer at http://www.ilok.com and install.
3. Make sure the plug-in license is activated to your machine or iLok dongle in the iLok License Manager.
4. If you are using VST2, Eventide Plug-ins are installed to the following locations by default. Please make sure that your DAW is set to look at the applicable custom folder: VST32: c:\Program Files (x86)\Common Files\Steinberg\VST2\Eventide\
VST64: c:\Program Files\Common Files\Steinberg\VST2\Eventide\
5. If steps 1-4 don’t solve your issue, close your DAW and run the plug-in uninstaller. The uninstaller is located at Start Menu->Control Panel->Programs and Features->Uninstall a Program
6. Open your DAW and rescan your plug-ins, and then shut your DAW again.
7. Deactivate and reactivate the plug-in license in iLok License Manager.
8.Reinstall your plug-in.
9. Reopen your DAW and rescan your plug-ins.Mac:
1. Confirm you have the latest version of your plug-in installed: https://www.eventideaudio.com/products/plugins
2. Confirm that you have the latest version of iLok License Manager installed.If you already have iLok License Manager installed, open iLok License Manager and select iLok License Manager → Check For Application Updates in the toolbar. If you do not have iLok License Manager installed, download the installer at http://www.ilok.com and install.
4. If steps 1-3 don’t solve your issue, close your DAW and uninstall the plugins.
Newer plug-ins have an uninstaller is located at /Applications/Eventide/Uninstallers.
For older plug-ins without an uninstaller, delete the following files:
AAX: Mac HD/Library/Application Support/Avid/Audio/Plug-ins/Eventide/<plugin name>.aaxplugin
VST: Mac HD/Library/Audio/Plug-ins/VST/Eventide/<plugin name>.vst
AU: Mac HD/Library/Audio/Plug-ins/Components/<plugin name>.component
Presets and Docs: ~/Music/Eventide/<Plugin Name>/ (whole folder)
5. Open your DAW and rescan your plug-ins, and then shut your DAW again.
6. Deactivate and reactivate the plug-in license in iLok License Manager.
7. Reinstall your plug-in.
8. Reopen your DAW and rescan your plug-ins.
9. AudioUnit only: If still not showing, some macOSes occasionally require a restart for Audio plugins to correctly scan.Let me know what happens.
November 25, 2023 at 8:05 pm #176123
Hi!
Same here.. I ran through all the steps but I get stuck on the “Select Licsense to Activate” window… I can only quit the other options are blurred out.
This while I am running the iLok Manager in the background. (See screenshot)
What can I do? I am on Mac10.11.6 El Capitan
Thanks
AMT
November 27, 2023 at 11:42 am #176175
Please email support@eventide.com and provide your iLok information and we can help you there.
June 24, 2022 at 4:34 pm #164175
This worked for me. For windows be sure to perform step 6. I didn’t and Blackhole didn’t show up in my plug-ins. Once I performed the process again and didn’t blow off step 6, Blackhole showed up in my plug-ins.
June 28, 2022 at 8:36 am #164207
Glad to hear this helped!
