Allocation: single_pel_cycles ???
Home Forums Products Rackmount Allocation: single_pel_cycles ???
    • #116237
      Hello, Eventide community.
      I am getting this strange error message when I try to send finished patch to Orville: “Allocation: too much sinle_pel_cycles”
      Any idea what it is supposed to mean? Have anyone seen a message a message like that?
      Thanks.
    • #156526
        This rather unhelpful message is trying to tell you that the patch requires more DSP resources than the Orville can provide. It may be that a parameter in the patch is set too high, or that it has too many modules (if from a sigfile).
        You should reverse your latest changes until the message goes away – there is no easy way to find the exact cause.
      • #156541
        Ah, I see. Thanks so much!
