Is there a way to have the H90 always in perform mode? I need to use it for live gigs and need to switch both algorithms on and off while performing. Sometimes I go accidentally to Select mode and the footswitches toggle between programs instead of turning on and off the effects.
There is no way to lock the H90 in Perform Mode. Once it’s in this mode it won’t exit out of it unless you press the Select Mode knob. If that happens you can just press Perform again to regain use the of act/bypass controls.
