Analog input 1 not working on H8000fw
Home › Forums › Products › Rackmount › Analog input 1 not working on H8000fw
Viewing 0 reply threads
    • #186224
      chris daniels
        been trying to setup an H8000FW inputs and outputs and no matter what, input 1 isn’t working and input 4 also has a much higher input level than input 2 and 3.
        ive reset the unit and updated the firmware and had a look inside. I’ve also used the routing app to set it up.
        So analog input 1 no input
        Analog input 4 about 8db higher
        both digital Adat and AES work fine.
        anything I should check? I’ve already take the  TV
        or I could take it back to where I bought it? But not sure if they could get it fixed easily? Is there anywhere in the UK that would be able to fix it?
        Chris
