Another Dumb DSP7000 Question
Home Forums Products Rackmount Another Dumb DSP7000 Question
Viewing 3 reply threads
    • #106840
      glennfin
      Is there anyway to save the Wet / Dry mix setting with a program? I did notice that some programs do have a mix parameter adjustment selectable from a soft key, yet others don't.
      Thanks again
    • #119904
      You can only save it if the wet/dry is a parameter of the preset, like the ones you mention.
      It is, of course, the work of a moment to add a wet/dry control uing Vsig or Vsigx, except for the 1-2% of programs that are already maxed out.
    • #119906
      glennfin
      What would the best way for novice Vsig user to go about adding a wet/dry control to a program that doesn't have one….look at a simple program that has one and replicate the structure?
      What would be a good example to copy? maybe one of the reverb programs?
      I'm waiting for my USB to serial adapter to arrive, then I'm going to start messing with Vsig.
      Thanks
    • #131095
      IDeangelis
      glenn
      we don't have these units anymore. You may want to load presets and check the parameters. As soon as you'll find one with a dry/wet balance, you got it!
      cheers
      I
