Anthology 1.0
Home Forums Products Plug-Ins Anthology 1.0
Viewing 6 reply threads
    • #105206
      Posted by DTA
      Greetings.
      I have installed Anthology. When I try to launch Band Delays (within Pro Tools) I get an error (Plug-in Load Error #325 Incompatible Eventide Library). And it will not load.
      Please advise.
      Dwight
      Please note that all other plug-ins work fine.
    • #116700
      Posted by Dan
      Have you had any Eventide software installed on your system before? What type of system do you have, are you running OSX, is it Mix or HD?
      Thank You,
      Dan Gillespie
      Eventide Inc.
    • #116701
      Posted by DTA
      Yes, I had Clockworks Legacy and Octavox loaded prior to install. I am running OS 10.2.8 with an HD system running PT 6.1. Did I miss something in the install instructions?
    • #116702
      Posted by Dan
      Probably not, can you do me a favor and go to the systemLibraryCFMSupport and get info on and tell me the version of Eventide Library and Eventide Helper. Did you run the installer in the same OS that you are using the plugs?
      Thanks,
      Dan
    • #127803
      Posted by DTA
      EV. Library 1.11
      EV. Helper 1.11b2
      Yes, 10.2.8 was installed during all 3 install.
    • #127804
      Posted by Dan
      I’ve found the bug, there is an update installer available at:
      Eventide Anthology
      Thanks,
      Dan Gillespie
    • #127805
      Posted by DTA
      Yes, the update did the trick. Thanks Dan. -D
