Anthology II, Factory Presets
Home Forums Products Plug-Ins Anthology II, Factory Presets
Viewing 4 reply threads
    • #107616
      lastudios
      I have need for a factory preset that simulates the H-3000 preset "Magic". We've attempted to transpose from older H-3000 to Factory plugin, but nowhere close. Its for an animated character that we still record for Disney. Does Eventide continue to add factory presets to the plugin suite?
      Thanks in advance
    • #121513
      DGillespie
      Hi lastudios,
      The H3000 Factory plug-in is based on the Patch Factory, Mod Factory one, and Mod Factory two algorithms of the H3000, while the Magic preset is based on the Layered Shift algorithm.  That being said, I took a look at the preset and it may be possible to recreate it on the plug-in.  Let me take a closer look, but I'll let you know in a couple of days.
      Dan
    • #121517
      lastudios
      Thanks Dan. I'll be waiting to see what you come up with. Thx
    • #132937
      DGillespie
      Here you go.
      Dan
    • #132938
      lastudios
      Thanks so much Dan to you and Eventide staff for the pre-set. Disney will thank you as well. We'll test this with the mixers 1st of next week, and let you know. We also got our 22 year old real H3000B back from you guys, after a major overhaul. Old technology still rocks.
      Steve H – LA Studios/FotoKem Engineering
