October 23, 2015 at 4:38 pm #112965
lifer
ParticipantHi
I have just installed Anthology X (1.01) on my Win 7 PT HD10 system. For some reason all the Clockworks plugins (H910, 949, Flanger, Phaser,Time align and Omnipressor) crash PT on startup. If i move them to the unused plugins folder PT starts up fine. Seems odd since all the other plugins work fine!
i trashed my preferences etc but no joy.
Anyone got similar issues? Ideas?
October 23, 2015 at 5:32 pm #141255
Hi Lifer,
What version of Pro Tools are you using? These plug-ins require 10.3.6 or higher.
Dan
October 24, 2015 at 3:20 am #141262
lifer
Participant10.3.10
October 27, 2015 at 9:25 pm #141308
Hi Lifer,
We're hearing a similar problem from a couple people with Windows 7 x32 systems. We're working on a fix at the moment. And should have a new release soon.
Dan
October 27, 2015 at 9:47 pm #141310
lifer
ParticipantAh great news..glad to know its not just my system 🙂
November 2, 2015 at 5:26 pm #141410
Hi Lifer-
We have this problem sorted out and should have an update soon, we're doing some internal testing on it at the moment before release.
-Tom
November 5, 2015 at 5:33 pm #141454
And here is 1.0.3, which should fix your problem.
Dan
November 7, 2015 at 4:35 am #141465
lifer
ParticipantFantastic! All fully working now thanks..
(Win Pro 7 64bit
ProTools 10.3.10 HD Accel)
March 27, 2020 at 10:23 am #154415
lifer
ParticipantHi
This problem has reappeared.
I think since installing the Spring demo. Now the plugins are placed into the unused plugin folder and when i try to put them back in i get a PT crash. It seems to be related to the MSVCR90.dll. I am still mon 10.3.10 HD and trying to keep this ailing system going for now. Its mainly flawless until this. Should i reinstall an old Anthology? I need both the Native and DSP versions working and they did until recently. Anyone help at all?
thanks
March 27, 2020 at 6:58 pm #154425
lifer
ParticipantHi
Im on Win 7 64bit (sp3) using PT 10.3.10 HD TDM
Part of the problem is needing to keep the TDM plugins going which is Anthology II at the same time as Anthology X. Support was kind enough to give me an NFR years ago to solve these conflicts but as ive upgraded and added some of your wonderful new plugins it has created a conflict again. Im trying to avoid going backwards but i need compatability with some old sessions. It has all been working wonderfully up until Spring demo install..if i remove H910 H949, Omnipressor Instant flanger phaser and precision time allign (one i REALLY need!) all is fine again.
March 27, 2020 at 2:58 pm #154422
Hi-
Sorry to hear about the trouble. Could you let us know what OS you are using?
I would recommend installing the latest iLok License Manager (www.ilok.com), and the latest version of Anthology (are you using X or XI?), which doesn't require external msvcr libraries (https://www.eventideaudio.com/support/downloads/anthology-x-installer-windows for Anthology X, https://www.eventideaudio.com/support/downloads/anthology-xi-installer-windows for Anthology XI).
If that doesn't work, email support@eventide.com and we can see about getting you an older version of Anthology which should work.
-Tom
March 30, 2020 at 2:26 pm #154447
Thanks for the additional info. As far as I know, there shouldn't be any problem running Anthology II and Anthology X side by side, even in newer builds of AX.
Did you try installing the latest build of Anthology X, which I linked above? Here it is again: https://www.eventideaudio.com/support/downloads/anthology-x-installer-windows
