Hello everyone,
I am new to using the H90 in insert mode and wonder how to properly set up the latency for H90’s insert loops when using digital devices, specifically the H9 in my case. Can anyone provide some guidance on how many samples I should set for the latency setting for H9? I tried to follow the manual but have not succeeded in making the signal “is silent or as quiet as possible.”
Additionally, I’m curious if the H90’s mixer will work with an H9 that has kill-dry enabled—that way, I won’t need to deal with mixing dry signals.
I appreciate any help or advice on this matter. Thank you in advance!
