Home › Forums › Products › Stompboxes › Anyone have some tips/setting for a great chorus sound from TimeFactor?
May 18, 2009 at 10:15 pm #106229harrysnapperorgansMember
I haven't had great luck getting chorus sounds from my TF, they are always a bit too flangey and just not quite right. Does anyone have any settings I can try?
ben
May 19, 2009 at 3:43 am #118618Burger666Participant
First, refer to this video to make sure that you agree with my version of a pretty good chorus (it's the Modfactor).
http://www.youtube.com/watch?v=k5oYHXtRCzM
Then, if you like what you hear, try these settings:
(Patch) 1:1
Chorus; Intensity – 43; Type – Shim; Depth – 38; Speed – 1.47;
Shape – Sine; XKnob – 0; DMod – 0; SMod – 0; Mod Rate – 1.38; Mod Src –
SineHope this helps. 🙂
May 20, 2009 at 4:24 am #118623idealguitarsMember
Hey Burger that's a great chorus. Thx.
May 20, 2009 at 8:09 am #118624harrysnapperorgansMember
thats great burger, but I was after a setting for TIME FACTOR . ..
Ben
May 20, 2009 at 12:40 pm #118625Burger666Participant
Oops. So you were. Sorry. The Timefactor is actually easier to pull great chorus sounds from but I don't have any specific settings. I'll see what I can dig up in the next day or so.
May 23, 2009 at 10:43 pm #129743beagleMember
Hi burger.
I love your settings and thx for your information.
By the way, I can not remember where I can get this but I found following setting for TF chorus.
Hope this help Ben.
vintage delay 50mix, 26ms, 2ms, 0, 0 20bit, dmod 10, 1.5hz, filter 50
Regards
May 24, 2009 at 12:46 am #118633geoParticipant
awesome setting for the modfactor, would you be willing to share any others? your phaser, rotary and flanger patches were also great.
thanks,
Geo
May 24, 2009 at 1:56 am #129744Burger666Participant
geo:
thanks,
Geo
Sure. Most of the better settings are listed in the comments beneath the actual video at http://www.youtube.com/watch?v=k5oYHXtRCzM
Unfortunately that's all I can offer because I'm a tweak freak and I've already mucked up the settings as they were in the video. I'll have to revisit them myself because they're better than the ones I've got now, heheh.
To save you the trouble though, here's the settings that I actually recorded. Hopefully, ahem, there will be a proprietary editor that will make it easy to save and exchange presets.
1:1
CHORUS; Intensity – 43; Type – Shim; Depth – 38; Speed – 1.47; Shape – Sine; XKnob – 0; DMod – 0; SMod – 0; Mod Rate – 1.38; Mod Src – Sine1:2
PHASE; Intensity – 18; Type – Positive; Depth – 99; Speed – .90; Shape – Sine; XKnob – 2; DMod – 0; S-Mod – 0; Mod Rate – .12; Mod Source – Sine.2:1
ROTARY; Intensity – Unused; Type – Std; Depth – R2.07; Speed – 3.25; Shape – R99H99; Xknob – 50; DMod – 0; SMod – 0; Mod Rate – 0.13; Mod Src – Sine2:2
TRMPAN; Intensity – 41; Type – Bias; Depth – 80; Speed – 5.32; Shape – Sine; Xknob – Unused; DMod – 0; Smod – 0; Mod Rate – .12; Mod Source – Sine.3:2.
Q-WAH; Intensity – 55; Type – Wah wah; Depth – 70; Speed – 7.59Hz; Shape – SMP/Hold; Xnob – 0; Dmod – 63; SMod – 0; Mod Rate – 0.12; Mod Source – Sine.9:2
UNDULATOR; Intensity:99; Type:Feedback; Depth:22; Speed (Sens):66; Shape: Envelope; Xnob – Feedback:75; D-Mod:0; S-Mod:0; Mod Rate:0; Mod Source:Envelope.Here are a couple that don't appear on the YouTube site. Again these are copied from the machine today and maybe different from the settings I used to record the video a couple of months ago. They'll be a good starting point though.
4:1
FLANGER; Intensity:8; Type:THRU-0; Depth:12; Speed:1.15Hz; Shape:Triangle; Xnob:MDO 99; D-Mod:0; S-Mod:0; Mod Rate:.13; Mod Source: Sine4:2
FLANGER; Intensity:99; Type: Positive; Depth:39; Speed:.58HzHz; Shape:Sine; Xnob:MDO 68;D-Mod:0; S-Mod:0; Mod Rate:.12; Mod Source: Tri.6:1
ROTARY; Intensity:Unused; Type: Standard; Depth:2.74Hz; Speed:5.07Hz; Shape:99/73; Xnob:Tone 45;D-Mod:0; S-Mod:0; Mod Rate:.12; Mod Source: Env.6:2
ROTARY; Intensity:99; Type: Positive; Depth:39; Speed:.58HzHz; Shape:Sine; Xnob:MDO 68;D-Mod:0; S-Mod:0; Mod Rate:.12; Mod Source: Tri.8:1
VIBRATO; Intensity:48; Type: Vintage; Depth:42; Speed:4.83Hz; Shape:Triangle; Xnob:Unused; D-Mod:0; S-Mod:0; Mod Rate:.12; Mod Source: Sine.I'll start another thread so that these can be more easily found. After all, this is a thread looking for a chorus sound for the Timefactor. Sorry OP!
