Home › Forums › Products › Stompboxes › ANYONE USING MIDICLOCK for the loopers beat tempo
June 3, 2008 at 4:33 pm #105662
I've tried mine here and when setting loop pre length to lets say 4 beats, the tempo of the loop does not stay in time with an external sequencer. Curious if anyone has had success with this, my tests have not been successful.
Firmware Beta 2.02
midi interface both USB from TF and midi from a echo-audio card
Sequencer cubase,Reaktor,traktor -
June 4, 2008 at 8:28 am #117539
It could be a very useful feature! I tried to use my drummer's midi clock to keep in time and record a loop to make some improvisation, but the pedal does not follow the beat.
Let's try to ask support if they can add this in the next release… -
June 7, 2008 at 7:16 pm #117550
I'm surprised no one else has responded, curious if anyone uses the Midi/USB on the the unit….
June 16, 2008 at 9:59 pm #117595
Do you have the same problem whether you use the usb for midi or another midi/usb interface? For example the Uno?
August 15, 2008 at 6:13 am #128901
I'd like to be able to sync up my loops with a Korg drum machine via midi. Is it possible? (I don't have the Time Factor yet, but this would be a must have for me).
Thanks
August 19, 2008 at 4:39 am #117779
Wow, amazing! I have a brand new Time Factor (anticipated it for months and months and finally clicked the 'buy' button) and thought I'd visit the forum to make my first ever post… ON THIS EXACT subject.
I have an Alesis SR18 that I am able to send MIDI tempo to. The Timefactor updates smoothly as tempo changes on the Alesis and displays 'R> x Beats' during looper recording. HOWEVER, it does not 'sync' the loop start / stop points with the nearest beat. I was really expecting that I would be able to create 'perfect' in-time loops using the MIDI clock, but no. Even though the Timefactor can see the clock coming in from the drum machine, it will start a loop upon pressing 'play' immediately, and not on the next beat.
Maybe I am missing something in the instructions? Because I am somewhat new to MIDI I asked a friend who is very familiar with the subject for what behavior he would expect. He said he would also have expected the loop starts to align with the midi tempo. I'm not talking about stretching the loop length to 'fill' x beats, but just starting playback 'on' the beat.
Thanks for reading and any help anyone can offer.
August 30, 2008 at 4:44 pm #117814
8 months after , it's the same problem for new users , i wrote a mail to support and the update is waited , i use Logic pro8 and all my expanders and drums machine receive and play perfectly the time code , except Timefactor and Eclipse , what's a pity for the Rolls's effect.
October 5, 2008 at 10:28 pm #117912
yeah i got this just simply assuming things would sync.
i used an electro harmonics pedal that has a midi out to sync midi gear to it.
both the rec/play buttons work as transport start/stop for drum machines. i was really hoping i could acheive this with the TF.
i want to both slave gear to the TF's tempo and transport, and have it slave and sync to other pieces of gear. no one seams to be using the TF as the master clock. i might have to go buy back the 16 second electroharmonics delay.
and why cant i output midi from the switches. only in bank mode? really a bummer
December 8, 2010 at 5:16 am #132298
Oh man this is so discouraging. Spent the money. Love the pedal. But the fact that loop mode midi output does not work "properly" is such a let down esp as Eventide seems uninterested or unable to fix it. Having a looper send midi clock to sync to a drum machine is so basic. If you are going to put a looper and midi in the same box it is understood that is how you would do it. Argh.
January 10, 2011 at 5:30 pm #132500
I have also been trying to get Logic 9 and the Pitchfactor to work via MIDI over USB. The tempo drifts and transport (start/stop) unreliable.
I see there is a video now about using Midi to sync 3 Eventide boxes but it would be great to have a tutorial on how to get the stompboxes in sync with external devices – in particular popular DAWs – surely there must be a raft of people wanting their Eventide effects in sync in PT, Logic, Live etc…..?
January 17, 2011 at 2:43 pm #132608
I just bought the time factor for studio work mainly and syncing to daw is essential, is this still a problem with the beta 3? i did not test it after updating…
