Anyway to find tempo of stored H9 patch?
Home › Forums › Products › Stompboxes › Anyway to find tempo of stored H9 patch?
    • #164237
      rskaudio
        Have a patch that I’m trying to recreate from a client’s H9 Pedal that has the delays set to Tempo Mode with (I’m guessing) a saved tempo since matching them set to 120 BPM isn’t correct. Is there anyway to view what tempo it’s clocking to?
      • #164238
        vvarvel
          Did you try pairing the pedal up with the H9 app and calling up the patch on the pedal?  I think the app will show all the parameters.
        • #187180
          checazzvo
            is there a way to use a H9 play a metronome click through an output while midi synching an exterior device? thanks
            • #187187
                No, the H9 does not have a metronome/click. You can use MIDI for tempo sync.
