Trying to use my Boss FS-5U in the aux switch to control tap tempo. It currently contrils "repeat"mode and I have tried 20 times to change this function to tap tempo and nothing works.
If you want to use this pedal you have to make a lead with a stereo plug on the TF end. Otherwise every time you press the FSU it shorts out both at the same time with a mono plug.
