Assigning external controllers to frequency
Home Forums Products Rackmount Assigning external controllers to frequency
    • #165573
      klango
        Hi, I’m trying to figure out how to control frequency from an external controller from Max through virtual faders and keyboard. Obviously this needs to be high resolution with two data bytes. What is the format the H9000R needs to see?  I’m not able to find this in the manual or forum.
        Thank you
        Peter
      • #165581
        Puppeteer
          The H9000 does support standard MIDI CC’s.  I’m not sure if it supports high resolution pitch bend, but this would be your best bet.
          I’m not sure if the H9000 supports NRPN’s for high resolution MIDI.
