Home › Forums › Products › Stompboxes › Assigning parameters to the H9’S X, Y, and Z switches
I have a problem with the control app.
Assigning parameters to the H9’S X, Y, and Z switches works on my IPad but not on the IPhone 13.
On the IPhone the app crashes if i double click on its rotary knob.
Thank you for bringing this up to our attention. I am also experiencing the same issue on my iPhone. We are taking a closer look at the problem. For now, it is possible to map XYZ values using the front panel of the H9.
Hello !
Still the same problem here in an iPhone 12. Do you have found any solutions ? Thanks !
Hi guys, identical issue here in 2025: the app crashes on my iPhone 15 Pro Max with iOS18.3.2 but not on my 2014 Ipad Air 2 with iOS 15
any solutions?
cheers
