AU Validation Failure, Blackhole – Mac M1
Home › Forums › Products › Plug-Ins › AU Validation Failure, Blackhole – Mac M1
    • #161589
      TopoTony
        I can’t locate any info regarding this problem. Final Cut Pro and Logic hang trying to validate the plugin components. Eventually, it will show it failed, but that’s after I force quit and re-launch a few times. I have to pull the components from the library to get the apps to open immediately. Is there a basic compatibility issue with the M1 Silicon Mac, and or Monterey?
      • #161593
          Sorry to hear you’re having a problem getting Blackhole to work. There shouldn’t be a compatibility issue with your system. Please follow the troubleshooting steps below and let me know what happens:
          Plug-in isn’t working in a DAW on Mac:
          1. Confirm you have the latest version of your plug-in installed: https://www.eventideaudio.com/products/plugins
          2. Confirm that you have the latest version of iLok License Manager installed (www.ilok.com).
          3. Make sure the plug-in license is activated to your machine or iLok dongle in the iLok License Manager.
          4. Close your DAW, and delete the following files:
          -AAX: Mac HD/Library/Application Support/Avid/Audio/Plug-ins/Eventide/<plugin name>.aaxplugin
          -VST: Mac HD/Library/Audio/Plug-ins/VST/Eventide/<plugin name>.vst
          -AU: Mac HD/Library/Audio/Plug-ins/Components/<plugin name>.component
          -Presets and Docs: ~/Music/Eventide/<Plugin Name>/ (whole folder)
          5. Open your DAW and rescan you plug-ins, and then shut your DAW again.
          6. Deactivate and reactivate the plug-in license in iLok License Manager.
          7. Reinstall your plug-in
          8. Reopen your DAW and rescan your plug-ins.
          9. AudioUnit only: If still not showing, some Mac OSes occasionally require a restart for Audio plugins to correctly scan.
          Other additional things a user should check for based on their DAW:
          Logic:
          Plug-in not showing up after above steps:
          Launch Logic Pro X
          Go to Preferences->Plug-in Manager and select “Reset and Rescan Selection”
          If the plugin fails validation, then copy the output of the white window, and send it to us
          If the plugin passes validation but still does not show in the Insert menus, try the following steps:Close Logic Pro X
          Make sure Finder is the active application
          While holding the Option key, click on the Go menu at the top of your screen and select Library
          Delete the following files from your User Library, if they are present:
          ~/Library/Caches/com.apple.audiounits.cache
          ~/Library/Caches/AudioUnitCache/
          ~/Library/Preferences/com.apple.audio.InfoHelper.plist
          ~/Library/Preferences/com.apple.audio.SandboxHelper.plist
          Then, open a Terminal window (Applications -> Utilities -> Terminal), and enter the following commands (type each command and press “Enter” afterwards)killall -9 cfprefsd
          killall -9 AudioComponentRegistrar
          Restart your computer
          Restart Logic Pro X
          Plug-in not passing validation:
          Launch Logic Pro X
          Go to Preferences->Plug-in Manager, and check if the plug-in is listed
          Highlight the plug-in and select “Reset and Rescan Selection”
          If validation fails, copy the output of the white window, and send it to us
