Automation for SP2016 reverb ?
Home Forums Products Plug-Ins Automation for SP2016 reverb ?
Viewing 4 reply threads
    • #114975
      geronimo
        Hi _
        I’m under SIERRA 10.12.6. and use your Plug-in with Digital Performer 9.52 (AU version); parameter automation won’t work .
        With REASON 10 (VST version), the Automation work fine .
      • #150229
        tlongabaugh
          Hi geronimo-
          We will look into the problem. Do you have any issues with the VST in Digital Performer?
          -Tom
        • #150233
          geronimo
            Since D.P.9 with VST version, the parameters move slightly at the beginning of the automation then nothing .
          • #150234
            tlongabaugh
              Ok – so you're experiencing problems with both VST and AU? I can reproduce the issue you describe with VST, but not AU.
              -Tom
            • #150235
              geronimo
                I just tested again; the automated parameters never move with the Audio Unit (AU) version _
