AUval fails to open CrushStation
Home › Forums › Products › Plug-Ins › AUval fails to open CrushStation
    • #115906
      tinarupp
        I recently bought CrushStation and AUval is not able to open and validate it. Here’s the result of the validation process:
        validating Audio Unit CrushStation by Eventide:
            AU Validation Tool
            Version: 1.6.1a1
            Copyright 2003-2013, Apple Inc. All Rights Reserved.
            Specify -h (-help) for command options
        VALIDATING AUDIO UNIT: ‘aumf’ – ‘CrSn’ – ‘Tide’
        Manufacturer String: Eventide
        AudioUnit Name: CrushStation
        Component Version: 1.1.1 (0x10101)
        * * PASS
        TESTING OPEN TIMES:
        COLD:
        FATAL ERROR: OpenAComponent: result: -1,0xFFFFFFFF
        validation result: Öffnen fehlgeschlagen
        If I tick “use the plugin” regardless of the validation process it is working in Logic without flaws but will show up in the plugin list under “incompatible plugins” which is not what I want. How can I fix this?
        Thanks
        Tina
        I’m running Logic Pro X 10.4.8 on Catalina 10.15.4
      • #154833
        tlongabaugh
          Hi-
          Sorry to hear about the trouble, this is the first report we're hearing of this issue.
          Could you verify that you have the latest version of iLok License Manager installed (iLok License Manager -> Check for Updates with ILM as the current app), and that the license is activated in the iLok License Manager?
          -Tom
        • #154834
          tinarupp
            Hi Tom,
            thanks for your reply. I’ve checked the ilok license and the version of the license manager. I’m already running the latest version and yes, the license is activated. As I said, the plugin will work corretly in logic, it’s just not validated. I have the same problem with various new plugins I bought lately. Arturia suggested it was a problem with the rights and made me check and change all the file rights for my components. That didn’t help either. Unfortunately I cannot pin it down to a certrain time when the problems startet. It may have been starting with the latest Catalina update. From a certain moment on, no more new plugin would validate which is really annoying!
            Tina
