Aux Switch P/B Setting
Home Forums Products Stompboxes Aux Switch P/B Setting
    • #105575
      Roobin
      I've just got the FS300 and have set one of the switches to toggle P/B. When I press it, it goes into play mode fine, but when I press it again, it goes back one bank. Eg if i'm in 2:1, press the switch, it goes into play mode for 2:1. Then I press it again and it displays bank 1. I've set Tip as Bk- and experimented with setting P/B for Rng and T+R. The other switch is set for Repeat or Tap Tempo. I've made sure that FS1-3 are not assigned. I've swapped cables. Any other ideas? Anyone else had this problem?
    • #117398
      Roobin
      I also tried a single switch, tried Tip, Ring, T+R…nothing fixed it. Could I ask someone else to try this, and post their results? I'd like to know if it is just me, or a problem on all TFs.
    • #117498
      mule
       Hi Roobin – I believe you found a bug.
      I just confirmed with Beta 2.0.2 BETA[4] it has this behavior, which is wrong.
      P/B function should toggle between PLAY mode and BANK mode, not decrement the
      Bank.
      joe
