Backing up my Pitchfactor – only 12 messages received?
Home Forums Products Stompboxes Backing up my Pitchfactor – only 12 messages received?
Viewing 3 reply threads
    • #111655
      Hi there,
      I'm trying to back up my all my Pitchfactor presets using SysEx Librarian (mac) with the PF connected via USB. But when I'm doing the backup, I get a message that only 12 messages was received. Shouldn't there be 100 messages, since there's 100 presets?
      Any ideas about what's wrong?
      Cheers,
      Nikolaj
    • #126011
        It really depends on exactly what and how you are asking the PF to do. It can, for example, send all presets as a single MIDI dump.
      • #126012
        Allright, thank you. I'm asking it to dump "all" (settings and all presets). And that results in between 10 and 14 messages – it's not the same amount of messages every time I do it… Is there a way to check if my backup is okay? 🙂
      • #136735
          A dump all will produce one message. I;m guessing that the problem is at the computer end.
