August 9, 2019 at 10:58 pm #115462
I’m trying to make a back up of my presets on a compact flash card. I tried using the bulk copy function mentioned in the manual however when I try to set the DEST FRM parameter it only goes to 099. I was under the impression that the card started at 500. I tried using the knob and entering 500 manually, but the it wont go past 099. I’m using a recently purchased SanDisk 256 MB card that I formatted in the Eclipse (at least I think it did, I didnt really get a confirmation that this was done)
What am I missing here?
Thanks for any help!
Greg
August 9, 2019 at 11:01 pm #152486
I'm a bit out of date with Eclipse, but I suspect that the backup just copies them as files to the card, and you would have to copy them back to use them.
It does not install them as card-based presets starting at 500.
August 10, 2019 at 4:04 am #152487
Thanks for the info. I’m not really trying to load presets from the card. I just want to have a backup. So what should I do?
Greg
August 10, 2019 at 1:47 pm #152488
I'll get back to you on Monday when I can get to an Eclipse
August 12, 2019 at 3:31 pm #152497
I tried it this morning, and, needless to say, it works fine for me.
I can duplicate your problem by removing the card, in which case the only writeable locations it can see are 0-99, so it does not allow higher values.
Sounds like either your card is no good, or there is a problem with the Eclipse card slot.
Suggest you try another card, and don't format it. Make sure your Eclipse has V4.0 or later.
I used a 1G Transcend card, and tried it both with its manufacturer's format and also formatted on the Eclipse.
August 12, 2019 at 8:00 pm #152500
Ok thanks for the info. I’ll give another card a try and see what happens.
