Because of additions to the System menus in the new
TimeFactor OS, sysex dumps using the"All" and "System"
commands are not compatible across TimeFactor versions. If you had backed up
your presets using an "ALL" dump before updating your TimeFactor and
wish to restore those presets after updating, you will have to go back and reload
the older OS that you made the backup from, dump your sysex file into
TimeFactor, then do a "PRESETS" dump and save the file. This file should now load into an updated
TimeFactor. Note: If you do not initialize after updating, then previous System
settings and stored Presets will not change.
