balanced TRS I/O to H90s unbalanced TS I/O
Home Forums Products Stompboxes balanced TRS I/O to H90s unbalanced TS I/O
Viewing 5 reply threads
    • #186086
      fiddlercrabseason
        I’ve read a couple posts (here and TGP) that confirm
        a) “…H90 will accept balanced TRS without issue..”, and
        b) “…the ring of the TRS cable will be shorted to the sleeve on H90”.
        I’d like to try to use H90s inserts to send/receive to/from a TRS balanced device that has “one phase shorted to ground”.  Does this complicate matters?  ie, does one device ‘shorting to ground’ and H90 ‘shorting to sleeve’ introduce any signal issues, and/or potential for damage to either unit?
        I’m probably overthinking this, but better safe than sorry. 🙂
      • #186090
        tsternfeld
          What’s the device? If it has one phase connected to ground, it’s not actually a balanced IO. Either way, I’d suspect that the grounded phase is the ring, which would be exactly the same situation as the H90 (and thus indistinguishable from using unbalanced I/O).
        • #186092
          fiddlercrabseason
            Thanks for the response!
            Tasty Chips GR-MEGA:
            https://www.tastychips.nl/downloads/GR-MEGA/UserManual/GR-Mega%20Manual%201.2.a.pdf
            As the response I quoted (in OP) was likely a translation, maybe there’s something getting lost in translation?
            Any further guidance you could offer would be appreciated.
          • #186093
            tsternfeld
              The manual there doesn’t say anything other than that the I/O are balanced.
              They do note that the I/O are diode-protected; the H90’s I/O are also diode-protected, so you are unlikely to do any damage to either device by connecting them under normal circumstances..
              Whether you have signal issues will depend (as always) on many factors, but unless you use very long cables I doubt it will be due to the balanced/unbalanced nature of the I/O.  If you practice good signal hygiene, you should be ok.
              • #186094
                fiddlercrabseason
                  Roger.  I’ll start saving some of my milk money. 😉
                  Thanks again!!
              • #186095
                tsternfeld
                  I should add, it does look like they have a low interpretation of “pro” level for their inputs, so I would see if you get enough signal with your H90 outputs in instrument level rather than line level (the H90 will comfortably exceed their recommended maximum input level, if pushed).
                • #186096
                    … I’ll start saving some of my milk money. 😉…
                    By the time it’s freely available out in the wild, the compounded interest should help soothe some of the sting.
