Band Delay Question
Home Forums Products Stompboxes Band Delay Question
    • #112755
      I had a Timefactor that I used the Band Delay algorithm on. I switched over to an H9 and purchased the band delay algorithm. For some reason, on the H9 I’m getting a bit of distortion or grit on the low end of the band pass with the H9 that I didn’t get with the Timefactor. Any clue what setting I should adjust to remove that or what might be causing that?
      Danke.
    • #140095
      h9controller
      Are you comparing these side by side and did you setup the H9's Band Delay algorithm exactly the same as your Timefactor's either manually or by sharing a preset?
      Can you share these settings with us?
