Bank UP/Down request
Home Forums Products Stompboxes Bank UP/Down request
Viewing 6 reply threads
    • #105860
      td2243
      Hey guys, I'm a long time eventide user and I love the new Time Factor.   It sounds amazing.    Here's my beef.
      Is there any possibility of an update where the user can change to a lower bank?   I hate having to cycle through 20 banks to get back to #1.   I can't for the life of me understand why the pedal was designed in this way, but it is.  Any suggestions?
    • #117909
       Easiest way is to program one of the AUX switches to give you bank down (BK-).
    • #117910
      td2243
      do you mean one of the jacks in the back?
    • #129072
       Yes – you can connect up to 3 extra switches to the Aux Switch jack on the rear panel which can be programmed in many useful ways. See the manual for more info.
      We use a Digitech FS300 footswitch which gives you the 3 switches and a jack lead.
      There is a limit to what you can usefully do with the 3 switches on the box, so the use of the AUX switch can be helpful to extend the functionality.
    • #129073
      I'm only using 5 banks so I set that as the 'bank limit' to keep scrolling to a minimum…just a suggestion 😉
    • #129080
      td2243
      I set that up this weekend and that should do it.   I don't know how I missed that in the manual.   I may get an auxiliary footswitch anyway.
      Thanks for the help guys.
    • #119016
      strangeaudio
      I have the same exact complaint. To resolve this, I'm using a MIDI foot controller. Allows banking up and down along with quick and easy patch changes.
