Basic Expression Pedal Question
Home Forums Products Stompboxes Basic Expression Pedal Question
Viewing 6 reply threads
    • #106065
      cacibi
      Sorry for the dumb question – but I'm new to the expression pedal thing and I am just wondering, when using the 25k VP Jr. volume as expression pedal, do you plug into the input or output of the volume pedal?
      Thanks
    • #118283
       The output would be best.
    • #118288
      cacibi
      Thanks much. The expression pedal really demonstrates the power of the unit. I've been an analog stomp guy for years but – was so blown away I have a Modfactor on the way!
    • #129378
      badmelonfarmer
       Hi There, a fellow tdpri member Cool
      I am trying to see if there is a way of sharing a single expression pedal between two units, a TimeFactor and a PitchFactor.
      Cheers
      BMF
    • #129379
       You should be able to do it with a Y-lead.
    • #129381
      badmelonfarmer
       Hi Nick,
       Would that cause an issue?
      I guess it would control both at the same time though.
       Cheers
      BMF
    • #129382
       It'll be fine, as long as your pedals are close enough not to cause a ground loop ..
